Hello everyone,
Before explaining my problem in depth I would like to let everyone know that I didnt have that problem prior to install my 2 velociraptor. I used to use 2 raptor 150 in raid 0 with the same hardware and vista 64 and never have I had that problem before.
I installed vista last week with 2 velociraptor in raid 0 on my p5e-vm hdmi. Since vista has build in raid drivers I dont have to load any f6 drivers (compared to xp where you need to do that). When the install finishes I install th rest of my intel drivers with my motherboard cd. Then randomly when I open internet explorer or other applications, i start to browse web page then randomly my pc will freeze (pause) (I can still move my mouse, but cant minimize windows or open start menu) and while this pause is on my hdd led is red non stop, then after 5-10 sec everything comes back to normal and everything works.
Keep in mind I install vista twice since this problem and the same problem appears.
I checked my vista log and here is what I found:
I know this file is in relation to my raid drivers. So what I think I will try to do tonight is install the latest intel chipset software. The raid driver version I have is 7.5 at the moment. If that fails then I will try to load updated raid drivers at the start of the vista installation.
Any other suggestion from you guys??
Here is also a thread about someone that seems to have a similar problem
http://forums.whirlpool.net.au/forum-replies-archive.cfm/1000177.html
