iaa not reconizing chipset on p4c800-e d
Bodega
iaa says that its not compatable with my chipset/SB. This seems kinda wierd because im trying to install it from my mobo CD. yes I already installed the chipset software utility or whatever its called, and yes my system meets all the minimum requirements outlines in the iaa readme. I have a 200g sata drive hooked up to the primary sata on the sb on the mobo. im only getting to use 130gigs because of the lack of iaa. ideas?
I believe the last boards that were compatible with the IAA were the 845pe boards. The 875 and 865 series are not compatible with it, I think because it's not even needed anymore.
in that case, any other suggestion on how i'd be able to use the other 70gigs of my hdd?
Possibly when you installed windows your primary partition wasn't set to the 200gb? If you are running XP, go to administrative tools, computer management, and under the storage group, click on disk management. Check to varify that the lost gb's are lost only because the primary partition doesn't include them. If they are there, but are not formated, right click on it and format. Hopefully this helps.
nope, only one partition. is it possible to switch the drive over to another sata controller that has 130+ addressing and still run windows off of it?
thats the new IAA thats only for raid in sata It should recognize the full 200 in winxp but who knows
For Windows 2000 Server there is a fix for drives over 130GB. I can't remember where I got it. But a machine of mine at work had the same problem.
