Andross182
- Sep 20, 2005
Hey gents,
Question for you all regarding my i9-9900k and SpeedStep. My previous build consisting of an i7-4790k and a gigabyte z97x-ud3h-bk board using the resource monitor I would see my CPU ramping up to 4.4 ghz or scaling down significantly depending on CPU load, however this doesn't seem to be the case with my 9900k. The only time I have seen the CPU frequency reduce it self was when system load dropped below 3% in which case the resource monitor showed the chip dip under 4ghz, only to ramp right back up.
The board I am using is a Gigabyte Aorus Pro with the latest bios. I have gone through my bios settings and verfied the CPU EIST FUnction is set to Auto, so it seems to be enabled from the bios side at least.
Has anyone else experienced this? It is not too concerning but I find it odd that I can have nothing running, and launch note pad and my system decides it needs to go full tilt to accomplish that task.
