i865PE vs. i865G
aNtHrAx323
Is there a major performance difference between the PE and the G? I know the G has integrated video, but that's the extent of my knowledge of the differences... Enlighten me.
Integrated video. That's all. The PE doesn't have it and theres another version of the chipset also. But I am not sure what that one has or doesn't have.
Some PE boards (like mine), have PATesque functions. It gives you a slight boost in memory bandwidth.
As long as you have your own video card, don't bother with integrated video. If you have a G board, be sure to set "AGP Aperature" to 0 in the BIOS so it doesn't use your memory for something you're not even using.
