i865/875 Northbridge Fan Replacement
Stugots
I finally pieced together a working system from both of my dead systems. I'm considering to go back to aircooling. The HSF on the northbridge on my Abit IS7 is crazy loud and I'm looking for a replacement. If I was running stock I'd consider just disconnecting the fan, but I'm running at speeds up to 284FSB. Does anybody have any suggestions on which HSF I should get that is not so damn loud?
Hows your case airflow? The Blue Zalman HSF is fine if you've got lots of airflow. (read: LOTS)
if not, I suggest any of the following:
Jing Ting Forcetake
Thermaltake HR-05 (Best Choice if it'll fit)
Swiftech 159-CU
Do you think I'll have a problem fitting the Swiftech 159 with a Zalman 7700 on an IS7?
It might be tight. I had clearance problems with my IC7-Max3 and a Thermalright 120.
Lemme find my camera and I will post a picture of one installed on a IC7-Max3 so you can judge your clearance.
I ended up buying the Swiftech 159. The entire unit does not fit without modifying my Zalman 7700. So I removed the fan off the NB and it fits tight, but it works. Now my system is dead silent, I love it.
