So I seem to be hitting a wall overclocking my i7 and I am wondering if people are having good luck overclocking with water. My cpu temp does not seem to be getting high 39c but my NB temps are hitting 60+.
umm, well if you can bump up the volts on your standard cooler and can get a higher stable OC, but are suffering from high temps then yes go for W/C, otherwise i wouldnt bother, its not gonna get you any more MHZ if your chip wont do it.
It's a 2.27ghz es hex core xeon. I just set the voltage high to not mess around I can back it down later to fine tune it. What other voltages should I be raising once I'm past 200 bclk.
Hmm would water cooling the north bridge help or does that have nothing to do with the bclk ? I'm fine memory wise mushkin 1600 cas six so just bump the speed down so that's covered. The system is loaded with 3 gtx470's and a pci-e sound card so the board is full.
My Asus P6TD had provisions to mount a 50(?)mm fan on the passive NB heatsink; not having one of those handy; and not wanting to spend a lot of money to see if it would help I bought an adapter to mount my old 60x25mm high speed fan on it. It didn't give me even one 1mhz of extra bclk. you might get something from watercooling it but I wouldn't expect a lot.
