I have an extra i7-950 setup laying around and have had it for sale a while with no bites... I need to replace my OLD SLOW ReadyNas with a home-built solution and was hoping to sell the i7 and go with an i3 for power consumption & heat savings.
However, I got to thinking... if the NAS I build is only used as a NAS (for now) will the i7 throttle down and use nearly the same amount of power as the i3?
Can I also throttle down the i7 in bios for even more reduced power?
I figure since I have this i7 already it may be beneficial to use it.
Power consumption and heat output are very important for my setup if there's a noticeable difference. To save 10%-15% power/heat I don't think that's worth it for me to upgrade.
