i7 Performance Problems
Vect-Rex
Alright, so I just finished building my i7 system and the first thing I do is run the mafia II benchmark. The score I receive is actually lower then my core 2 duo system which surprised me. Anyways, I go into the bios and overclock the cpu to 4.2ghz. I then run the mafia II benchmark once again and the results hardly changed. I find this very odd and was hoping someone could explain this. Also, the other thing I noticed is that windows, cinebench and maifa II will show the cpu clock lower than it really is. For example, I'm clocked at 4.2ghz and windows will show 4.03ghz, but cpu-z shows the clock accurately. I'll post the bench results:
1st run:http://img822.imageshack.us/img822/9171/60222653.png
2nd run:http://img23.imageshack.us/img23/4774/oddr.png
Incorrect readings: http://img31.imageshack.us/img31/1677/16018479.png
Well, stock i7 950 is more than enough for both Mafia 2 and your HD4800 series video card, so such a small increase in FPS is normal. As for the readings, it goes like that: if you left the multiplier untouched (x23), then all applications would report frequency correctly, but as soon as you set it to max (highest multiplier available when all 4 cores are loaded, in your processor's case - x24) - most "not so smart" applications would still think your're running at x23. In such a case, there's no need to worry, since you're running running at x24 (just like CPU-Z reports).
It's quite possible that you are GPU limited, which is why you didn't see any increase in speed when you went to the i7. As far as cooling goes, what are you using? At high speeds you'll need a pretty beefy cooler for an i7.
@4.2 I would think the h50 would be straining immensely to cool that chip.
