so, for some reason, using coretemp, my 920 I7 at all stock settings, won't idle below 40degrees no matter what.
Here is my setup
MSI X58 Pro motherboard
6GB gskill ddr3 1333mhz
core i7 920
Noctua nh-u12p
Lian Li PC7 case
under load with prime95 it stays around 70degrees or so.
40 at idle seems pretty high compared to what others are getting.
even with hyperthreading turned off it still doesn't make a difference.
any ideas?
Here is my setup
core i7 920
Noctua nh-u12p
Lian Li PC7 case
any ideas?
