Thanks Zero, but you did not at all answer the question.
Dont worry I thought the same thing after reading his post.
Well, there isn't really anything else to say. Aside from the MSI X58 Platinum (which should be avoided), most of the i7 boards are around the same price and have similar features. None of them really have better bang for the buck; it's just down to which board you prefer.
What's wrong with the MSI Platinum?
