i7 build need feedback
hylo
Gaming, photoshop work, VM for dev work
< 1800 CAD before tax/shipping
3) Where do you live?
Ontario Canada
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
CPU, RAM, MB, video card, PSU, HSF
800D, WD1002FAEX x2, intel 80G ssd, LG bluray writer, (also have 2 8800gt's i can use over if I should wait on the videocard)
6) Will you be overclocking?
Yes, air only, aiming for 3.5ghz - 4.0ghz
samsung 245t 24"
Plan on ordering as soon as I get feedback.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
sata 3.0 (6gbps), SLI and xfire support
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
no
I can't decide between the P6X58 and the UD3R. Concerns are ease of overclocking and the coil whine.
I am also undecided on RAM, mushkin, gskil, or corsair are my top picks but open to suggestions.
Here's the list:
https://secure.newegg.ca/WishList/MySavedWishDetail.aspx?ID=11300734
Mushkin Enhanced Redline 6GB (3 x 2GB)
ASUS P6X58D-E
Intel Core i7-930
XFX Black Edition XPS-850W-BES 850W
XFX HD-587X-ZNFV Radeon HD 5870
Noctua NH-D14
Win7 pro
Thanks
I would go with this ram instead:
$168 - G.SKILL Ripjaws Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
This motherboard:
$230 - GIGABYTE GA-X58A-UD3R LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
This lesser power supply (850 is a bit overkill for a single card setup like that, unless you really are planning on Xfiring soon, and in that case, stick with the 850):
$108 - XFX P1-650X-CAH9 650W 80 PLUS BRONZE Certified Modular Power Supply
And personally I would prefer this cooler over that giant freaking Noctua one:
$80 - CORSAIR Cooling Hydro Series CWCH50-1 120mm High Performance CPU Cooler
If you can squeeze it in, add a second 3x2GB tri-channel RAM kit. Then use a RamDisk program (search for it here) and convert some of that RAM into a super-fast swap disk for Photoshop, or allocate some of that extra RAM for your VMs (if you like to use multiple VMs at once).
@shadowssong I definitely want to keep xfire/sli open. I considered the H50, and love the look of it, but ultimately decided that the performance didn't justify the risk of a leak. That MB is the other one that I was considering and seems to be recommended a lot on here.
@tiraides I can definitely squeeze in 12GB, in fact I was considering 12GB to start, except when I read some other posts on here, someone mentioned that you can get a better O/C when only 3 ram slots are in use (not sure how accurate that is) but really, anything over 3.5 I would be happy with. 12GB would be ideal for me, i'm just worried about running into issues over-clocking.
Having all of the RAM slots occupied will affect overclocking performance, but I can't give you a hard number or figure. If overclocking is important for you, then I recommend sticking with one tri-channel kit.
TBH I have never heard of the H50 leaking. If it did because it is a completely self-contained prebuilt system I'm sure corsair would pay for any parts it destroys.
