Boardin087
- Jul 2, 2003
Gaming/casting games
No budget, would like to save as much money as possible and stay under 1000 but I'm not going to worry if it goes up a few hundred more, i plan on having it for awhile.
3) Where do you live?
PA, but I can get to a Microcenter when I travel to MD for work if needed.
PSU/MOBO/PROCESSOR/Memory/Case
Monitors/Mousepad/Mouse/Keyboard/Graphics Card/Hard Drive, Optical drive
6) Will you be overclocking?
Probably?
32 inch tv and 24inch monitor. Will prob go back to 2 24's
Not a rush but within a month
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
usb 3.0, sata 6gb/s, everything else optional.
I have Windows 7 64bit.
Probably?
