KrazeyKami
- Dec 31, 2010
Hi all,
My setup:
i7 975
Asus P6T SE
12 GB OCZ3G1333LV2G (which runs at 1066 at stock, had to manually up the DRAM to 1333 and set 9-9-9-20 timings)
I just got an i7 975 and read a bit about OC.
I saw examples where you can leave everything stock (turn off speedstep and c-state) and just up the multiplier. Some could up to 28x and have a core voltage of 1.242.
I however, noticed the following:
At stock, I run around and below the 1.0V:
When upping the multiplier to 27, I already have a CVoltage of 1.272..
And at 29, I hit 1.440...
As where this guy claims to get to x28 at 1.242 w/o tweaking, and he actually has to modify the vcore settings to get it run at 4,1 MHz (x31), with the same voltage as I already have at x29.
http://www.anandtech.com/show/2777/9
How come my voltage is so high? I haven't actually changed anything, apart from letting my memory run at 1333:
I tried reverting those settings all back to Auto, but the voltage still was too high (no change).
I would like to run on a stable 3.8 w/o having to change my core voltage, and I think 1.4 is a bit too high compared to the various examples right?
Anything else I should change?
Regards,
Kami.
My setup:
i7 975
Asus P6T SE
Regards,
Kami.
