broodovermind
- Nov 6, 2010
How much of a performance difference is there? Would the extra 2 cores help with anything other than rendering animation?
How does the 980x compare to two Intel Xeon E5620 2.4GHz LGA1366 Quad-Core procressors??
Hmmm, then i might lean towards xeon, because i know zbrush and maya both use multi threading. Not sure about photoshop or modo.
What makes you say that? I'd expct them to be about the same in highly multithreaded applications In applications with limited or no multithreading i'd expect the 980x to blow the xeons away.In multithreaded applications the dual 5620s will blow the 980x away.
2.4x8=19.2
3.33x6=19.98
