Says who? 930 should be slower at stock.I have a 940 I picked up last year, at stock speeds is the new 930 faster even though it's clocked lower.
Did intel make 940 DO stepping CPU's or are they all CO?
No good reason to go with the 940 then, even with the higher multi the 940 most likely wont clock as high as the 930 if you plan on overclocking.All 940s are C0. When the D0 stepping came out, the 940 was replaced by the 950.
