i7 930 CPU-Z Bug?
looks like its using the boost multiplier and bclk. not sure if its a glitch but check your bios and see if there is a seperate bclk/multiplier setting for the boost. on the 930 the boost was just +1 on the multiplier unlike SB which has a wider variation in boost multiplier. you can double check cpu-z with a much older version like 1.50.4 or something along those lines. that should still support the 930.
yeah i just downloaded 1.50 and it's giving me the correct readings. shoulda thought of that before hand lol. thanks for the help
no problem, weird glitch but i'm guessing its a coding bug related to sandybridge/ivy bridge support.
