Blackstone
- Mar 8, 2007
Okay so here is the deal. I have a x58 chipset Asus P6T and i7 920 that has served me well for years.
I recently added two GTX980s. My PSU is a Corsair HX750. 12 gigs of Corsair Dominator GTX DDR3 memory.
I am running Windows 10 preview BUT, these issues occur in Windows 7 so this is a hardware problem.
This system (see signature) with SLI enabled will not survive Prime 95 torture test for 30 minutes. One thread crapped out. Nothing is overclocked.
Further, the system crashes in BF4 with SLI enabled after about 20-30 minutes. Basically just when the action gets good it will either lock up or it will reboot itself.
So I have a situation where the system is unstable both when CPU stress tested and GPU stress tested.
Memtest is okay after 30 minutes.
I used have a GTX590 which was SLI on a stick. This is my first dual slot attempt at SLI, but the GTX590 I think had PSU requirements which were similar or even exceeded two GTX980s. So I do not think PSU is overloaded.
Should I RMA the cards? I am thinking about scrapping the whole system and going with Haswell E. What do you guys think is the culprit?
