hello,
i have built a new computer and i was not settled with the processor's core frequency, so i wanted a little bit of overclocking.
My system was stable for 2 days,.. and today i had one BSOD and one black screen that needed a restart so far. Both problems in games. BSOD in jedi outcast and black screen in GTA4.
Here are my specs:
Core i7 920 @2.66 GHz
MSI x58 Pro-e motherboard
6 GB RAM - Kingston 1333Mhz - 7-7-7-20
MSI HD 5970
750W Fortron PSU
Win 7 Ultimate x64
Here are the BIOS data:
multiplier: 20x
base-clock: 175
adjusted core frequnecy: 3500
Memory latency: 8-8-8-24
Memory ratio: 4
Adjusted Dram frequency: 2800
Cpu voltage: +0,150
Cpu Vcore: 1,392
CPU Pll voltage: 1,86
QPI voltage: 1,25
Dram voltage 1,68
HT is enabled and turbo is disabled. I am not looking for very high frequency i am looking for a 100% stable system. More weird I had run Intelburn test 2 days ago and it passed perfect with 10 runs. I am grateful for any kind of advice.. thank you
EDIT: i have enabled the turbo in order to get multiplier 21x ... many people on forums said it solved their problems so i will give it a try and we will see...
Here are my specs:
MSI HD 5970
750W Fortron PSU
Win 7 Ultimate x64
multiplier: 20x
base-clock: 175
Memory ratio: 4
Cpu voltage: +0,150
Cpu Vcore: 1,392
QPI voltage: 1,25
Dram voltage 1,68
