Hey everyone, just got my TRUE in the mail for my new build, and i just wanted to make sure my temps are fine and are where they should be. I'm also running the TRUE in push/pull with to Scythe Ultra Kaze 3K rpm fans, though i may switch them for the Scythe Slip Stream 1900 rpm to lower the noise.
Anyways, idle:
100% Load on All Cores ( Look at Max temp, forgot to take the screenshot when it was actually running ):
I'm also gonna run the test for an hour later before i go to sleep to see the results then.
And if anyones wondering about the weird cpu clocks, i didnt mean to overclock, i just changed the multiplier on the memory so they'd run at correct speeds and it happened to auto-overclock in order to make the change
Anyways, idle:
