vertigomhs
- Aug 1, 2008
so i just got my new i7 rig running and i figured id try one of the pre set OC options in the BIOS of my board, i selected the 3.3ghz option just to see what temps im going to see later when i OC.
when i loaded up windows i ran linx to stress it a bit and see how the temps looked, i also loaded cpu-z to check the voltage and i noticed that the voltage was at like 1.43v!
so i quickly stopped the stress test and shutdown, and reset all the BIOS options to default.
i was basically wondering if i could have damaged my cpu in any way by running it with that many volts, i know the limit is like 1.375 right?
thanks.
thanks.
