i7 920 overclocking help
jtvd78
I am going to build an i7 920 rig soon, and I need a little help before doing my first ever overclock. I know that there are mant other threads like this out there, but I really need this help. I am hoping to acheive a 4Ghz overclock, using the h50 cooler. I will be using this motherboard and this memory.I want this chip to last 5 years. is 4Ghz for 5 years even possible?I have researched on the internet for a while and here is what i think the proper BIOS settings would be:
Speed Step = DISABLED
ALL TYPES of spread spectrum = DISABLED
Auto Disable PCI Frequency = DISABLED
V Dimm( Memory Voltage)=1.65 max
Uncore (BLCK X ULCK) = 2x Memory
Turbo Mode = DISABLED
BLCK ( Baseclock ): 200 (is this too high?)
CPU multiplier: 20 (should I use 21?)
Memory multiplier (Memory Multiplier X BLCK = Memory frequency) : 8
C-State = DISABLED
LLC (Load Line Calibration) = enabled
Intel HT(Hyper Threading) = ENABLED
Hardware Prefetcher - ENABLED
I know that I missed all the QPI stuff. I'm going to need some clarification of that. I relly need help with CPU , VTT, QPI, IOH, NB, SB, PLL etc. voltages.Also, what does the Uncore do and what is VTT?. Is there anything that I missed?
Sorry for all the questions, but in a n00b when it comes to overclocking.
I found some screen shots of the bios, and i wrote up the CPU part of it. It took a while, but I got it. I need some help in filling in many of the places here it is:
-Ai Tweaker: Ai Overclocker Tuner - [Manual said:
CPU Ratio Setting - [20 or 21]
Intel (R) SpeedStep (TM) Tech - [Disabled]
Xtreme Phase Full Power Mode - [Enabled]
BLCK Frequency - [200 or 190]
PCIE Frequency - [120 MAX]
DRAM frequency - [1600]
UCLK frequency - [3200]
QPI Link Data Rate - [?]
CPU Voltage Control - [Manual]
CPU Voltage - [?]
CPU PLL Voltage - [?]
QPI/DRAM Core Voltage - [?]
IOH Voltage - [?]
IOH PCIE Voltage - [?]
ICH Voltage - [?]
ICH PCIE Voltage - [?]
DRAM DATA REF Voltage on CHA - [?]
DRAM CTRL REF Voltage on CHA - [?]
DRAM DATA REF Voltage on CHB - [?]
DRAM CTRL REF Voltage on CHB - [?]
DRAM DATA REF Voltage on CHC - [?]
DRAM CTRL REF Voltage on CHC - [?]
Load-Line Calibration - [?]
CPU Differential Amplitude - [?]
CPU Clock Skew - [?]
CPU Spread Spectrum - [Disabled
IOH Clock Skew - [?]
PCIW Spread Spectrum - [Disabled]
-Advanced >>>CPU Configuration
C1E Support -[?]
Hardware Prefetcher - [Enabled]
Adjacent Cache Line Prefetch - [?]
Intel (R) Virtualization Tech - [?]
CPU TM Function - [?]
Execute Disable Bit - [?]
Intel (R) HT Technology - [Enabled]
Active Processor Cores - [All]
A20M - [?]
Intel SpeedStep (TM) Tech - [Disabled]
Intel (R) C-STATE Tech - [Disabled]
