Hey Guys,
I recently built my first computer with the follow components;
ASUS P6T Deluxe V2
ASUS ENGTX260
CORSAIR 620HX
Intel core i7-920 Bloomfield 2.66GHz
2x CORSAIR DOMINATOR 6GB (3 x 2GB)
Western Digital VelociRaptor WD1500HLFS 150GB
Western Digital Caviar Green WD10EADS 1TB
Noctua NH-U12P SE2 120mm SSO CPU Cooler
Everything went together great and has been up and running.
I noticed that my cpu was running at 2.67ghz and my memory at 1071mhz.
I decided to follow this video guide here: http://www.mefeedia.com/entry/asus-p...cing/12157000
Ai Overclock Tuner - Manual
Intel(R) Speedstep(TM) - Disabled
BCLK Frequency - 190
DRAM Frequency - DDR3 - 1523mhz
CPU Voltage - 1.35
DRAM Bus Voltage - 1.66
Now when I put in these settings I can't boot into windows, but if I change the DRAM Bus Voltage to 1.64 I'm able to login to windows and then it crashes.
Now my questions are
Is my problem these BIO settings or is my PSU not powerful enough?
Do I need to upgrade to HX850w or HX1000w PSU to achieve these settings?
ASUS P6T Deluxe V2
ASUS ENGTX260
CORSAIR 620HX
CPU Voltage - 1.35
