i7 920 Overclock
Azphira
Does this seem reasonable?
Testing with easytune before setting permanent in bios.
Been noticing the vcore goes up to 1.32v when the cpu is idle.
-edits-
Set all voltages from auto to default, temp so far has dropped 10 degrees to 69c still seems stable. ...so far. All the green lights went out on the EX58-UD4P 3 blue lights on.
Seems very normal for a C0/C1 chip. I actually prefer to disable the Turbo (x21) multiplier as my system became a little unstable with it enabled (when it kicked in) and I didn't want to bother giving it extra juice for that. I'm running a 1.28 vcore at @ 3.7ghz so your right there with the rest of us.
