I've been trying to get a little extra umph out of my 920 tonight and I've hit a temp wall. Prime95 ran without any errors for over an hour at 3.78 GHz but my temps where hitting 82 degress Celcius on both cores #0 and #1. I'm running by BCLK at 180 with the multiplier x20 and turbo enabled (x21). CPU voltage is 1.2. I was running my Cooler Master V8 with the fan running full speed. Is there something else I can try to get my temps down or should I just look @ better cooling? I figured I could do much better than this so I'm a little disappointed at this point.
BTW, I'm running BCLK @ 160 right now (3.36 GHz) and a 1.1 CPU voltage. Prime 95 after an hour is around 64 degrees C.
Thanks,
Throc
Thanks,
Throc
