eva2000
- Apr 14, 2002
Max 230Mhz BCLK
I had all but given up after I found my initial max Bclk 32M Pi stable BCLK of 220Mhz with tight 878mhz 7-7-7-17 timings.
But I'd like to thank Hazzan (233BCLK) and Solarfall (230BCLK) for their inspiration with their DFI UT X58-T3EH8 max BCLK attempts as this prompted me to keep working at it
After numerous bios reboots and trying looser timings and a few voltage combinations, I finally surpassed my previous max memtest86+ v2.11 bootable BCLK of 224, moving all the way up to 230-231 memtest bootable.
Enough for a quick boot into windows for a CPUZ Validation at least
System specs
- Intel Core i7 920 3836A756
- Thermalright Ultra 120 Extreme + LGA1366 Bolt Thru kit + 2x 120x38mm Scythe UltraKaze 2000rpm 87cfm fans in push/pull
- DFI LP UT X58-T3EH8 R.A51 - 01/06 beta bios
- 128MB Gainward FX5200 PCI
- 2x1GB Corsair DDR3-2133C9DF Dominator
- Ram cooling: 3x 60x25mm Sunon 23.5cfm Maglev fans
- 750GB Samsung HD753LJ
- Pioneer DVD-RW
- 1KW Corsair HX1000 psu
- WinXP Pro SP3 full nLite updated hotfixes
01/06 Beta Bios settings used:
Code:
[B]Genie BIOS Setting[/B]
[B]CPU Feature[/B]
Set VR Current Limit Max: Disabled
Thermal Management Control: Disabled
EIST Function: Disabled
CxE Function: Disabled
Execute Disable Bit: Disabled
Virtualization Technology: Disabled
TDC Enable: Disabled
x TDC Limit: 0
TDP Enable: Disabled
x TDP Limit: 0
[B]***** Logical Processor Setting *****[/B]
Intel HT Technology: Enabled
Active Processor Cores: All
[B]DRAM Timing[/B]
Memory Control Setting: AUTO
Memory LowGap: 1024M
DRAM Command Rate: AUTO
CAS Latency Time (tCL): 9
RAS# to CAS# Delay (tRCD): 9
RAS# Precharge (tRP): 9
Precharge Delay (tRAS): 24
REF to ACT Delay (tRFC): 88
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): 16
ACT to ACT Delay (tRRD): 6
Row Cycle Time (tRC): 31
Read CAS# Precharge (tRTP): 6
Four ACT WIN Time (tFAW): 31
[B]Voltage Setting[/B]
O.C. Shut Down Free: Enable O.C.S.D.F
CPU VID Control: 1.350v
CPU VID Special Add Limit: Enabled
CPU VID Special Add: Auto
Vcore Droop Control: Enabled
[B]DRAM Bus Voltage: 1.875v[/B]
[B]DRAM PWM Switch Frequency: Nominal[/B]
DRAM PWM Phase Control: 2 Phase Operation
[B]CPU VTT Special Add: +0.0750v
CPU VTT Voltage: 1.53v[/B]
[B]VTT PWM Switch Frequency: Nominal[/B]
VTT PWM Phase Control: 2 Phase Operation
CPU PLL Voltage: 1.80v
[B]IOH/ICH 1.1V Voltage: 1.27v
IOH Analog Voltage: 1.25v
ICH 1.5 Voltage: 1.7v[/B]
ICH 1.05V Voltage: 1.05v
DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
ADDR/CMD VREF Control: Disabled
x DIMM 1/2 ADDR/CMD Bus VREF: 110
x DIMM 3/4 ADDR/CMD Bus VREF: 110
x DIMM 5/6 ADDR/CMD Bus VREF: 110
CPU QPI Drive Strength: Normal
IOH QPI Drive Strength: Normal
Exit Setup Shut down: Mode 2
O.C. Fail Retry Counter: Enabled
O.C. Fail CMOS Reload: Disabled
PPM Function: Enabled
Turbo Mode Function: Disabled
1 core Max Turbo Ratio: 22x
2 core Max Turbo Ratio: 21x
3 core Max Turbo Ratio: 21x
4 core Max Turbo Ratio: 21x
CPU Non-Turbo Clock Ratio: 17x
[B]* BCLK/UCLK/QPI Controller Settings *[/B]
QPI Control Settings: Enabled
QPI Link Fast Mode: Enabled
QPI Frequency: AUTO
CPU Base Clock (BCLK): 231 Mhz
Boot Up CPU Base Clock: AUTO
PCIE Clock: 103 Mhz
DRAM Frequency: 6x
UnCore Frequency: 12x (optimal to keep Uncore at 2x DRAM Frequency)
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
Settings highlighted in bold were what I played with to reach 230 BCLK.
