CursedMind
- Jan 6, 2009
So, hi there guys. This board and the vids were awesome, and by watching and reading along I actually found myself re-doing the orders for components of my all purpose gaming&work rig.
I wasn't into PCs much, as I am an Mac user ever since my first encounter with computers, and by that I've not been looking on components much, neither cooling. Just to explain why I'm so careful in doing the OC.
To get to the point:
I've built and set up a stock clocked machine with
CPU: Intel Core i7 920
CPU Cooler: Thermalright Ultra 120 Extreme 1336
MB: Asus Rampage II Extreme
all inside a Cooler Master HAF 932 Case
GFX: Asus stock OCed GTX280 (wich I mention because its actually the hottest thing I have in that Case when that machine is under load... idle at 47°C)
I did get drivers, SpeedFan and Prime95 and what I'm looking at now irritates me a little:
After 1 hour of 100% load on all cores, HT enabled, no bios settings done whatsoever, CPU temperature is at 39/40°C with 20°C insider the case. ( room temperature at 21°C )
While this is probably something I should be happy about, I'm not quiet sure that I tested the right way. That OC/heat charts done by Kyle show very diffrent numbers with the same CPU cooler being used. Can anyone give me a hint what you guys do to test your builds and get accurate readouts for Core Temps ?
And how careful I should be with this machine when OCing to 3.8 with HT enabled ?
EDIT: When I get back to idle temp goes back down to 20°C in less then two minutes.
