i7 920 but only two cores, help please.
Yes_sir21
I just bought a new i7 920. But my motherboard doesnt show all the four cores neither do any of the cpu metering, like cpu-z, speedfan etc. The motherboard is Gigabyte x58 ud5, how do you get the 4 cores to show ?
Im sure this is a minor and usual mistake but i cant figure how to get it right :/.
Thank you. :)
You should see 8 cores (4 physical+ 4 virtual with HT enabled). Did you try reading this from the inside the bios setup? Did you install windows or try to boot a windows os that was installed for some other processor?
It was on existed OS(coz i haven't backed up data yet), but i didnt install the cd-driver that came with it, the so called flash bios. Is that the issue maybe ?
How many cores do you see? What motherboard? What OS? Sounds like you don't have multi-core and/or hyperthreading support turned on in BIOS.
yes, thats probably the issue...What OS are you on?
Im using windows 7 32 bits.
I see only 2 cores and 2 Threads according to cpu-z and speedfan.
MB is Gigabyte x58 u5.
I dont know how to turn on hyper threading as this is the first system all by myself. I`ll have to check the bios again thou. So you don't think its a bios update issue ?
try a livecd either with a disc or usb flash drive, I just made one using Linux mint and it recognized all 8 logical cores
Press the Start key, type msconfig, and press Enter. Click on the Boot tab, then on the "Advanced options..." button, and uncheck the box next to "Number of processors:". Reboot. That should fix the problem.
This is what I was going to say.....but rather than uncheck it, be sure its set to "4" ..I would bet yours is set to "2"
but either way should work.
I don't think that this is what the OP is talking about. This wouldn't effect the number of cores and threads showing up in Task Manager for instance.
Actually, yes it would....The same thing happened to me a while back when I went from an E6600 to a Q6600 ..the OS was not aware of the switch, and was only using 2 of the 4 cores.
the above method was what I needed to enable the other 2 cores.
If you uncheck it, it will default to the number of cores that the BIOS detects. So it's best to do that rather than leaving it as a manual setting.
It absolutely would. That setting controls the number of cores that the OS sees.
Yay !! Thank you sire. That fixed now i got 4 cores and 8 threads and very tempted to overclock. Is it wise to OC with stock cooler or should wait for a better heatsink (noctua) ? All i need is to raise the bclk and vcore a bit right ? Which currently are 133 and vcore 1.25.
Also what is troubling me is the slow boot, there is dark window saying something like "Verifying DMI pools" and listing hdds and so on. Is it possiable to jump over ?
It's not a good idea to overclock an i7 with the stock heatsink. You should get an aftermarket heatsink.
Told you so :p.
This DOESN'T effect the number of cores and threads showing in Task Manager. Looking at my Q6600 that I just put together, Task Manager is showing all 4 cores and this setting in msconfig is 1. I've not changed it yet.
Here's a screen shot of the Q6600 system showing it:
Glad this fixed you problem however!
Btw. what number of processor do i set in the msconfig>advanced option> number of processors ? I get to chose up to 8 processors now (guess that means hypthreadning is on. ) but only 4 for can start OS or what ?
ill go for that then.
so basically this wasnt an issue on mb side but rather windows not "detecting" all the cores..
Do i still need to install the cd that came with mb then ? :p
but its not set to 1..because its not checked off......check it, reboot and then see what happens.....
So for best performance, you are suggesting to leave it unchecked and 1 or checked and what number ?
Just leave it unchecked, and the number it's set to doesn't matter because it's not used when the setting is not enabled.
I started reading this thread and quickly got a headache lol, if you have an i7 you should be seeing 8 cpu readings. I also wouldnt recommend carrying over new hardware onto an existing OS install.. I did this with WinXP for years and was amazed how much better it ran when I finally formatted & did a clean OS install. (Currently dual booting XP 32bit & Win 7 64bit).
My i7 920:
