Ok so today I finally finished my new build, and doing some quick temp testing to see where I stand and if I need to reinstall the heatsink or not. I am using Real Temp 3.0 and CPUID. CPU was running at stock speed, according to CPU-Z 2.8Ghz (I guess its the Turbo V that gave it the .2Ghz boost)
-i7 920 (B0)
-Prolimatech Mega Shadow Deluxe (With Ultra Kaze 2000, I turned it down to 1500rpm tho)
-P6T v2 Deluxe MOBO with 6 120mm Fans in the case.
-Tuniq TX-3 Thermal Paste
Please comment as I will start messing with OC soon and would like to reach 4Ghz just want to be sure 1st how much I will be limited by my temps.
Idel:
Core1 - 34
Core2 - 32
Core3 - 35
Core4 - 31
10 min of Prime95 Blend Test.
Load: (Max) These are the Max temps that it gat to
Core1 - 57
Core2 - 57
Core3 - 58
Core4 - 55
Thanks
-i7 920 (B0)
Idel:
Core1 - 34
Core2 - 32
Core3 - 35
Core4 - 31
Core1 - 57
Core2 - 57
Core3 - 58
Core4 - 55
Thanks
