Seems 1366 has more potential life as well, or as far as I've read, it seems that it will be around longer.
i7 950:
Higher overall cost of entry
Triple-channel RAM
Triple-GPU and Quad-GPU if the MB supports it
Future upgrade path? Yes
i7 870:
Cheaper cost of entry
Dual-Channel RAM
SLI or CF, PhysX with reduced performance if aforementioned is being used.
Future upgrade path? No
i7 950:
Triple-channel RAM
i7 870:
Dual-Channel RAM
There is an upgrade path from the i7 950 though, if anything you use benefits from hex core you can go that route. The socket is essentually dead but there is an upgrade path from what he is planning on building now.
edit: Path is to strong a word, he has one more step he can take with that system.
I think he meant like a year down the road when the hex core will undoubtedly be cheaper second hand.
this is the question that a lot of people who are looking at sandy bridge are asking now. I have not seen a great increase in performance between a 2600k and a 875k. It sounds like any CPU that you can OC to around 3.4 is a win.
Sorry for that being a bit off topic, but back on. the 870 does use less power, so i think it still depend on what you want. The 950 system will cost more and eat more power, but will deliver better performance.
Socket 1366 is getting a little bit of love, but not enough to call it an upgrade path. It will be EOL in a year. Hex price are a big question, but I dont think that they will be under $350 so if you call that an upgrade, then ok, i don't.
An upgrade path, is what AMD typically has. Intel has typically been lousy with upgrade paths. Not to say you can't do it, but an intel upgrade usually costs as much as a low-end next generation system.
Last bit: It's anyone's guess where the prices will be in January, but i think we can agree that the 950 and 870 prices will go down a bit then.
