Alright so im going for a stable 4ghz on my 860, three of the cores are totally ok with that but one of them is not.
I am running 22x182 = 4015.
1.3vcore in bios - 1.352 load
1.25vtt
vdimm 1.65 as spec'd by Ram.
All features disabled including HT as she just gets too hot and all im trying to run is FSX which doesnt seem to care if its on or not, only thing left on EIST @ auto to allow for the extra 22 Multi keeping bclock and vtt as low as possible.
All Cores 0,1,2,3. are LinX 25 pass stable @ 20000 load temps max 76c
All Cores 0,1,2,3. OCCT stable 12hrs load temps max 70c
P95 on the other hand....
Cores 0,1,3. 12hrs blend test, small fpu stable.
Core ,2 physical core (3) 38m = Fail.
I have tried different Multi + Bclk configurations all resulting in pretty much the same thing... so my conclusion, core (2) physical core (3) is my weak link.
Now my question is, is there anything i can do about this, do the PCH\PLL voltages help in anyway when overclocking... anyone else run into a similar issue and found a magic bullet?
Any help, insights or recommendations would be greatly appreciated...
Thanks
1.25vtt
Thanks
