Having a hell of a time with this processor.
Hardware in question:
Gigabyte P55A-UD3
i7-860
4x2GB Corsair XMS 1600
I can do 3.8ghz (190x20) at 1.35 vcore 1.29 vtt no problem, as long as hyperthreading is off.
If I put HT on I've tried up to 1.45 vcore without success and only get stability around 3.4ghz (180*19).
Is it normal for HT to kill the OC this much? Load temps with HT off top out ~64C. With HT on I am topping out at 68C.
Am I safe to keep adding voltage? It seems like it is dropping a lot under load. From what I read I do not want LLC on if I value the lifespan of my chip.
Edit: Been running 3.4 with HT on at 1.35 volts without a problem for a while now. Any increase in speed and I get prime 95 errors almost right away. I'm leaning toward it being a motherboard issue at this point rather than a chip issue.
Gigabyte P55A-UD3
i7-860
