I7 860 - Base clock limited
[L]imey
Hi guys,
I'm still learning to OC my new I7,
I've hit a wall where I can't get above 178 base clock rate no matter what I do. The system won't POST. I've reduced the multiplier down to it's minimum of 9, I've turned the RAM ratio down as low as it gets. I've tried higher voltage on the core and the uncore.
I suspect it has something to do with memory timings, but I'm really in the dark.
Anyone with experience lend a hand?
I'm using a biostar TP55 board with the processor. Perhaps I'm just mobo limited?
Thanks in advance.
