So, sort of a noob question. I built my system back in March and the MB is a Maximus IX hero. Using the Asus overclocking, I ended up stable since that time with what it called a 16% overclock. I did not adjust anything in the BIOS manually.
This past Friday, I started getting Blue Screens with WHEA uncorrectible errors. I could not get it to boot. It just kept looping with the Blue Screen popping up before it got to the login screen. I removed RAM, drives, peripherals to no avail. I then went into the BIOS and tinkered and the problem was solved by disabling Turbo mode. Since then, I upped vcore and enabled Turbo and it is working again. My vcore was 1.136 prior to adjusting, and it is now working at 1.146 the same as it was prior to the issue this past Friday.
With all that out there, my question is whether or not having a completely stable system to suddenly have issues like the one I described and being fixed by increasing vcore is a sign my CPU is starting to die. If so, I am not too happy having that happen in a 6 month old system. My last CPU was a 2500k that lasted 6 years.
Thoughts?
Thoughts?
