Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Intel Speedstep? If you enable that it should just automatically underclock and undervolt the CPU when it's idle, then ramp the voltage and frequency back up to whatever you set it at when it is being used.
