I've been monitoring the CPU core temperatures last few days and I am a little bit concerned with core deltas so I would ask for your advice/thoughts - I am not sure if I should reapply the TIM (used MX-4).
I am running a 5820k@stock on Sabertooth X99 and Prolimatech Megahalems cooler in Fractal Design S chassis. The heatsink is paired up with a 140/120 mm pair of fans together with 4 Fractal Design's GP-14 140 mm fans so there should be ample airflow.
I am using Prime95, calibrated RealTempGT 3.7 and Asus AI Suite for temperature monitoring. Here are the results (temps are measured with all fans at full speed):
- Small FFT -> RealTemp core temps 62-70 C (AI suite reports CPU temp of 55 C)
- Blend -> RealTemp core temps 52-62 C (AI suite reports CPU temp of 51 C)
It is always the same core spiking in temp and heating its neighbour.
Idle temps are high 20ies - ambient 19-21 C.
As I had always done before, I've cleaned both CPU IHS and heatsink surfaces with 70% isopropyl, used the 'credit card method' to apply the TIM to heatsink, spreading it as evenly and thinnly as I could. After cleaning the heatsink I used a plastic glove to "rub in" TIM onto the contact surface (so as to fill in the microgaps as best as possible).
The question is - is this delta normal or should I reapply the TIM? I've been told core temps delta should be no higher than 3 C but then again I came across an official mail from Intel to a customer saying the core temp measurement is not officially supported - so I am confused; what should I hunt for?
