clayton006
- Jan 4, 2005
I'm running with the rig in the sig. Question about my overclock.
I'm running LLC at level 2 (Level 1 being no droop) and running at about 1.335v fixed vcore. At 4.7 this is rock solid and doesn't seem like a bad chip or overclock results.
That being said I would like to try for 4.8GHz 24/7 if I can. If I use fixed (or eventually go for offset voltage), what should be the max vcore I run through this thing for a "safe" 24/7 workload? I'm running custom water, so right now I have one core that peaks at 70c, the rest stay in the mid to low 60's at peak, low 60's high 50's average.
I should probably be okay with 4.7, but want some opinions. Thanks!
