M76
- Jun 12, 2012
I currently have an I7-3820 cpu that runs at 4375Mhz I had to lower the frequency from 4500, because I started to have stability issues. When it was new I could run it at 4625. The CPU is now two years old. Should I be worried? I'm not used to this kind of decay all the cpus I owned before didn't loose their overclockability over time at all.
Maybe I ran it too high voltage? What is acceptable for these cpus?
If I decide to sell it what would be a good upgrade? The 5960X and the 5930K are not in my budget. So the only options are 4930K, or 5820K, or wait for 6700K.
