I finally decided to overclock my 2.6ghz i5 to a more interesting clock. I'm completely new at the whole overclocking business so I was hoping you seasoned tweakers might give me a few pointers. My harware is:
- 2x G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel
- Intel Core i5-750 Lynnfield 2.66GHz LGA 1156 95W Quad-Core
- GIGABYTE GA-P55M-UD2 LGA 1156 Intel P55 Micro ATX Intel Motherboard
- Noctua nh-d14 cooler
I was watching this specific video for reference: http://www.youtube.com/watch?v=Llqhe3N1cJA and referring to this guide too: http://www.overclockers.com/3-step-guide-overclock-core-i3-i5-i7/
One thing I noticed in the video is that the guy suggests not to even mess around with voltages as the system is pretty smart about picking the right one to keep things stable.
Here are the settings that I ended up (after some very minimal tweaking) with according to CPU-Z:
Couple of questions for those of you who, unlike me, know what they're doing:
1) max temp on the CPU has been 66C so far. Is that cool or is that low enough that I should try to increase things a bit more?
2) in the SPD tab, CPU-Z says that max bandwidth for that ram stick is 667mhz whereas as far as I can tell it's a DDR3-1600 stick so it should be able to handle up to 800mhz. Right now the frequency is at 720, is my ram about to die?
3) Ram frequency is at 720, so I stil have overall (when doubled) 180mhz to spare. Is the ram going to be a bottleneck if I don't bring is as close as possible to 800mhz or is it fine the way it is?
4) The system doesn't seem to be stable. Running prime95 for an hourish earlier to a reboot, so I'm trying to figure out what I should be bumping down to make it more stable. Any suggestions?
Thanks!
Thanks!
