i5 Mounting in Antec 900
crowat
So I am about to assembling my PC update. I got the following components.
i5 750
MSI P55 GD65
I purchased a CoGage True Spirit heatsink.
http://www.frozencpu.com/products/9...Socket_LGA_1156_LGA_1366.html?tl=g48c369s1037
I also got the 1156 Bolt-thru-kit.
http://www.frozencpu.com/products/1...Venomous_X_Ultima_90_Cogage_True_Spirit_.html
My question is since my case does not have a hole behind the CPU will I need to cut out a hole in the case? The mounting bracket is not made out of plastic so I don't know if there will be any contact and conduction w/the case. I figured I might as well ask some more experienced members than guess.
Thanks for the help.
Most of the backplates fit with no interference. No need to cut a hole, but assemble it and check for clearance.
