i5/i7 Turbo mode vs OC.
GeminiCool
After seeing some reviews and reading the general feel comments I began to have a few questions. It seems fair to say that the turbo mode on the new Intel CPUs works very well. So well, that in day to day usage it's often noted that the new CPUs feel quicker than the i7/X58 and the X4/AMD.
My question is, if you OC the i5/i7 and have to disable turbo mode, does this 'hurt' the day to day quick feel you get when turbo mode is on?
Is it better to do a 'light' OC with turbo mode enabled?
Can you enable / disable turbo mode on the fly for applications that don't get a boost from multi core?
Are we at the dawn of an app launcher that will fix process affinity to the turbo boosted core?
The real questions are the first few... I'm very interested to know if turbo mode feels faster than OC'd. Then of course comes the question about a “tweaked OC” where it’s optimized for single (or dual do to HT) vs multi core.
Thanks.
Turbo mode basically just raises your multiplyer by one, so it is overclocking just the same, somewhat limiting though if thats all your going to use.
While I understand this simple idea, I don't believe it is that simple in Lynnfield. When one core is active the speed bump can go from 2.66 up to 3.2.
Does this begin to really show the question? If four cores OC to 3.4Ghz... or let's say your heat sink is so so... maybe one core can OC to 3.6 or 3.8. Maybe if you play games that only use 2 cores, a better overclock for you is 3.0 normally and 3.6 in turbo...
Lynnfield is shown all over to provide a significant boost in turbo mode, upwards of what 17%? This is a real world feel kind of question... I don't know if benchmarks will capture it correctly.
It raises the multi by 4 for the i5 750 when 1 or 2 cores are used. By 1, if 3 or 4 cores are used. I have my max oc at 4.2 with turbo enabled, 24 x 175. So when no more than a dual core is needed, it runs 4.2ghz, when 3 or more cores are used, 21 x 175 = 3.675ghz. The onboard pcie controller starts getting a little whack at 200ish on these new cpu's, so using turbo mode lets me keep base clock speeds well below 200, yet get a fair oc. The pcie controller on the cpu needs more volts than you can really throw at the cpu safely I believe, to get a high base clock speed, above 200ish. The pcie controller therefore will be a limiting factor in how high an oc you can get. This is one of the drawbacks compared to the socket 1366 cpus. This is what I have learned in the last 3 days messing with it anyway.
dcc, thanks.
I had read about the pcie voltage concerns... and to be honest, I've been overclocking CPUs for 10+ years and I NEVER get the uber high OCs to remain 100% stable for any prolonged period of time. My 1.6A @ 2.4 lasted a record 2 years.. then died.... My 6750 is holding at 3.5Ghz now My 6600 has been backed down to 3.2.
I appreciate your comment about having to add significant voltage to the core to stabilize the pcie... and reduce the life of the CPU...
I think 1.4 vcore is about all I will do on air, and get the most oc from that setting.
