I5 750 Question
CUSL2MAN
My system is as follows:
Gigabyte ga-p55a-ud3
I5 750
gskill F3-12800CL9D-4GBNQ 2x2gb
I have been running this system for months on stock settings. I recently installed watercooling to try some overclocking. I am stable all the way till 170 on pretty much stock voltages. When i go any higher i get a fail to post. I figured it was the processor. I did some reading and decided to lower the memory mult as low it would go to 6.0. The system would boot fine to at least 190, that is where i stopped. Does this sound like the memory is what is blocking me from hitting any higher than 170 on the 8.0 Mult.
That is where i'm at right now. Anything anyone can recommend would be great.
Thanks,
Rob
