So I've been fooling around with this i5 system a bit for the last two weeks. I haven't really been able to push it since I'm on the stock intel cooler (which is an utter piece of crap, wow has their quality gone down). Anyway, I've been running different configurations with 200BCLK because I'm shooting for 4.0GHz (200x20) once I can get my Noctua NH-U9B installed. Currently I'm running the CPU at 3.4GHz (17x200) with 1.1625V Vcore and 1.23V VTT. The problem is I can't enable the more advanced power saving states (C4, C6, C7 I think, they're all grouped under one option my BIOS) otherwise the system will freeze once getting into Vista.
I originally thought the problem was my VTT was too low (after comparing it with other overclocks, especially from "official" reviews). I think cranked it all the way to 1.33V, and while this allowed me to finally pass the green Vista loading bar, I still froze on the desktop, so I don't think that's the issue, although it does seem related. Also, cranking the voltage just to turn it down seems counterproductive
. I don't think it's CPU clock related, as the issue still occurs at 3.0GHz (200x15). I haven't fine-tuned it, but pretty much soon after I clock over stock speeds (2.66GHz), these states will fail. I'm guessing it has something to do with the high BCLK clock, which I need to run my RAM at 2.0GHz (200x10). C1E and EIST are both enabled and I haven't had any problems, I would just like to enable these last power saving options if possible as the cooler, the better, due to my small case.
So, does anyone have any experience with this or any suggestions to try out? The other thing that crossed my mind was that this is a BIOS issue and I'll have to wait for Gigabyte to come out with something new (currently using the F4h BIOS).
Thanks,
Mr. K6
Thanks,
Mr. K6
