i5-3570K OC and temps
Discussion in 'Intel Processors' started by Dawgdoc, Jul 20, 2012.
  1. Dawgdoc
    Dawgdoc Limp Gawd
    209
    Feb 16, 2007
    New rig as follows:
    CPU: I5 3570K
    Mobo: Asus P8Z77- Deluxe
    Ram: 4 x 4 GB G.Skill Ripjaws DDR3 - 2133
    GPU: EVGA 680GTX 4gb
    PSU: Corsair HX850
    Storage: OCZ Vertex 4 SSD 512gb
    Case: Coolermaster HAF XM
    CPU Cooling: Asetek 570LX
    What temps should I be looking for with this CPU under water, and what range of OC should I be shooting for?
    Ambient temp is around 70F here, and P95 27.7 on stock everything Im hitting like 65C/70C/72C/72C.
    I know Ivybridges run a little hot but that seems a little bit warm for me for the cooling Im running?
    Any links for good info appreciated TY :)
  2. FrostBite
    FrostBite [H]ard|Gawd
    1,082
    Jun 2, 2004
    You are 70C on water with no overclock? Did you not apply any thermal paste?
  3. Robin B
    Robin B Limp Gawd
    209
    Jul 14, 2004
    Hmm thats about the same temps i see on my 3570@4500 1,26v on air.
  4. Dawgdoc
    Dawgdoc Limp Gawd
    209
    Feb 16, 2007
    OFC i applied TIM rofl....
    Ceramique2.
    As I said, I was concerned that those temps were too high, and I guess its confirmed now. :p
  5. DejaWiz
    DejaWiz Oracle of Unfortunate Truths
    18,658
    Apr 15, 2005
    Wow, yeah. Have you tried reseating the waterblock?
  6. Dawgdoc
    Dawgdoc Limp Gawd
    209
    Feb 16, 2007
    Nah...gonna do that tonight though.
    Just not familiar with s1155 or ivybridge. I know ivy runs hot but wasnt sure what expected or normal temps were.
    Last computers I put together and overclocked were all s775 so im out of the loop by a few years....
  7. DejaWiz
    18,658
    Apr 15, 2005
    Well, for your notes, my Xigmatek Dark Knight with it's included 120mm fan and Nano Diamond TIM on my 3770K at stock clocks:
    Idle is roughly 21-25C each core
    100% load with IBT is around 52-77C each core
    Overclocked to 4.5:
    Idle is 22-26C per core
    IBT load is 76-87C per core
    I mostly run stock right now, as I've yet to encounter any game or program that actually needs my i7 to be faster than that.
  8. FrostBite
    1,082
    Jun 2, 2004
    In a few summary notes for IB:
    - ~4.2 - 4.4 seems to be the average overclock with stock voltage/no offset
    - 4.5 and higher if you increase voltage/offset
    - Heat is the main problem with IB and you'll probably run into this before voltage
    - With no longterm figures for IB, there aren't a whole lot of safety and longevity (i.e., 24/7) for voltage information. 1.2 seems to be safe, I've seen a lot of people run 1.3 and 1.4 for daily use, but they hit temp problems since it starts to run really hot even good cooling
  9. IntelEnthusiast
    IntelEnthusiast Intel Enthusiast Team
    534
    Feb 21, 2011
    With the IntelĀ® Core™ i5-3570K and the Corsair H100 I was hitting 82c on LinX at 4.2GHz with 1.2v.
  10. SonDa5
    SonDa5 [H]ardness Supreme
    7,403
    Aug 20, 2008
    OP stock MB voltages may be slightly high.
    1,2v is probably enough voltage to get most i5-3570ks to 4.2-4.5GHZ.
    Key voltages to keep temps down are PLL, offsett, IO/VTT.
    Not sure why the MSI MB doesn't have LLC/Offset voltage so I don't need to mess with it but many motherboards use LLC/Offset voltage settings to maintain constant voltage under load which can heat up a cpu if too much is applied. I've seen this LLC/Offset voltage cause over clocking problems for some people when they have it too high and their cpu gets hot under load.
    On my MSI Z68 GD65 G3 I run my ram at 2400mhz which requires 1.05v on cpu IO voltage with CPU at 4.5GHZ. Other motherboards BIOS list the IO voltage as VTT. The CPU IO/VTT voltage is important for stabilizing memory.
    PLL voltage is also important for stabilizing CPU. I run mine at 1.65v with CPU at 4.5GHZ.
    I run 1.17v on my CPU voltage for 4.5GHZ.
    Each mother board is different in how it conducts electricity but from everything that I have seen on SB or IB the voltages that I have listed effect the stability and temperature of SB/IB the most.
    I have over clocked SB and IB with the same MB and IB is much more sensitive to voltage. My experience is that just a few slight difference in voltages on any of the key voltage settings that I have listed will effect stability and temperature of CPU.
  11. Dawgdoc
    Dawgdoc Limp Gawd
    209
    Feb 16, 2007
    Thanks everyone for all of the info.
    Much appreciated.
    Reseated the CPU cooler and running about 10C cooler now, with a stable 4.3Ghz OC. Pretty poor OC at this point but I only played around for about 20 mins before I stopped.
    Alot of catching up to do with the new socket, new chipset, and new BIOS. Last time I overclocked was s775 :p
    Thanks again!
