My settings for 4.7GHZ
-i5-2500K 4.7GHZ,Gigabyte Z68XP-UD3P,HyperX 8GB,GTX 560Ti OC,Samsung 1TB+SSD CACHE,Corsair V2 600W,Win 7 64bit.
Sometimes it will work for a week other times boot loop, I can play hours and hours of BF3 and skyrim, do lots of photography. It's 10+hrs prime 95 stable and many many runs of Intel Burn test at both medium and high. Yet sometimes when you boot the system it will hit a boot loop, and keep getting to the bios logo and turning off, then turning back on again. You have to leave the power cable out for a bit, then reboot while pressing DEL to get to the bios setting's screen, to reset back to 4.6GHZ.
However If i then go back to the bios and set to 4.7GHZ with my above settings it will work perfectly again, any advice?
BIOS VERSION - F6
\MB - ( M.I.T )/
\Advanced Frequency Settings/
CPU CLOCK - 33X
BCLK - ( DISABLED ) left at default 100mhz
EXTREME MEMORY PROFILE XMP - ( PROFILE 1 )
SYSTEM MEMORY MULTI - ( AUTO )
\Advanced Cpu Core Features/
CPU CLOCK RATIO [33X]
PWN FREQUENCY CONTROL [ AUTO ]
INTERNAL CPU OVER CURRENT PROTECTION [ AUTO ]
INTERNAL CPU PLL OVERVOLT [ AUTO ]
RATIO CHANGES IN OS [ DISABLED ]
INTEL BOOST TECH [ AUTO ]
RATIO 1 - 4 [ 47 ]
TURBO POWER LIMIT [ 250 ]
CORE CURRENT [ 250 ]
CPU CORES ENABLED [ ALL ]
CPU ENHANCED HALT C1E [ AUTO ]
C3/C6 STATE SUPPORT [ AUTO ]
CPU THERMAL MONITOR [ DISABLED ]
BI-DIRECTIONAL PROCHOT [ AUTO ]
\Advanced Memory/
EXTREME MEMORY PROFILE X.M.P [ PROFILE 1 ]
SYSTEM MEMORY MULTI SPD [ AUTO ]
PERFORMANCE ENHANCE [ STANDARD ]
DRAM TIMING SELECT SPD [ AUTO ]
CHANNEL A - B [ AUTO ]
\Advanced Voltage Settings/
MULTI-STEPS LOAD-LINE [ LEVEL 6 ]
CPU VCORE [ 1.340V ] ( TEST WITH PRIME 95/INTEL BURN TEST AND THEN LOWER THE VOLTS UNTIL UNSTABLE TO FIND YOUR LOWEST STABLE VOLTAGE )
QPI/VTT VOLTAGE 1.050V [ AUTO ]
SYSTEM AGENT VOLTAGE 0.920V [ AUTO ]
DYNAMIC VCORE [ AUTO ]
GRAPHICS DVID [ AUTO ]
CPU PLL VOLTAGE 1.800V [ 1.800V ]
DRAM VOLTAGE 1.500V [ 1.616V ] ( LOWER OR HIGHER DEPENDING ON MEMORY REQUIREMENTS )
DRAM VREF 0.750V [ AUTO ]
DRAM TERMINATION 0.750V [ AUTO ]
CH-A/B ATA VREF 0.750V [ AUTO ]
CH-A/B ADDRESS VREF [ AUTO ]
\Misc Settings/
ISOCHRONOUS SUPPORT [ ENABLED ]
VIRTUALIZATION TECH [ ENABLED ]
\Power Management/
HPET SUPPORT [ ENABLED ]
HPET MODE [ 64BIT ] - 64bit windows versions
\Pc Health/
CPU SMART FAN CONTROL [ DISABLED ]
