TweakCrazy
- Jul 7, 2011
Core i5 2500K @ 4.5GHz (100MHz X 45)
Rev. D2, stepping 7, MAX TDP 95W
Socket 1155 w/MSI P67A-GD65
Generic aftermarket heatsink w/AS
Mem Voltage = 1.5V DDR3 1600
(CL9-9-9-24)
Mem X.M.P = on
CPU PLL = Overvolting turned off
LLC (Vdroop) = Low Vdroop setting on
VCSSA = auto setting
VCCIO = auto setting
PCH voltage = auto setting
Speed Spectrum = off
EIST = off
Turbo Mode = off
System Power = Intel SVIC
V-Core and Temps:
Stable at 1.350V, but very hot, so much that throttling kicks in under load (All four cores over 85C-90C, too close to TJ Max).
In between the 1.300V and 1.350V BIOS v-core setting, system is still stable but too hot. Under load, the V-core increases up to 1.3970V with the 1.350V BIOS setting.
I did not get a chance to document the increase with the 1.300V BIOS setting.
With the 1.295V BIOS setting, the system is very stable, reported as 1.304V in CPU-Z, and under load going to 1.344V. Temps are now 34C Idle and 84C under load (running Prime95).While stress testing with these settings, I did notice the temperature coming down from 84C to 78C. I will continue to decrease the V-core and stress test, but I wanted to see what you guys thought about these high temps and V-core changes. I'm guessing the V-core increase is related to my "Low Vdroop" setting and Intel's SVID technology increasing power to the CPU as needed.
http://i.imgur.com/Wh9Il.jpg
Thanks for your help,
TweakCrazy!
(CL9-9-9-24)
Mem X.M.P = on
EIST = off
Turbo Mode = off
V-Core and Temps:
TweakCrazy!
