My 3dmark 11 results indicated that my CPU clock was only 1.6ghz. Could this be right? I checked CPU-Z and it seems to be idling at 1.6ghz.
How do I know, if I'm doing something CPU intensive, if the CPU is running at full speed?
3Dmark records that info after the run is complete when the CPU has already dropped back down to idle, its pretty common. Mine always say 1200 or 1600mhz depending on the CPU on newer SB/IB systems.
