[BB] Rick James
[H]ard Dawg
- Apr 4, 2004
Ok so I'm looking at going with a water cooling for my PC and I'm reading up on all these parts, kits and etc and I'm really confused on what's the best for performance, price and how long the system will last me.
Basically I'd like my entire rig to be water cooled, from the Processor all the way down to the chipset on my motherboard. I don't really need the hard drive or ram to be water cooled.
I'd like to stick with building my own water cooling system as opposed to purchasing a kit.
What parts would you guys recommend?
Here is my system.
Athlon64 3400 +
Gigabyte K8N Pro *nForce3 150 board* (I'd like my chipet water cooled)
X800 XT PE (will arrive this week)
Those are the 3 main things that I'd like water cooled. What set up would you guys suggest for a water cooling system. I'd like to overclock this system a little bit as well. Something low noise would be nice and keeping it in the $200 - $300 rang would be nice as well.
Let me know what suggestions you guys might have.
Thanks,
Here is my system.
Athlon64 3400 +
Thanks,
