1. Where is a reputable retailer to buy MiniITX boards?
2. Are there Socket A MITX boards?
3. Do they use the same components as regular PC's? (PSU, Memory, pci/agp)
The site I am most familiar with for Mini-ITX is mini-itx.com. They are quite reputable, the only downside being a bit high prices on some things, and they're located in the UK. (But they ship worldwide.)
I'm not familiar with any Socket A Mini-ITX motherboards. The majority of them are made by VIA, and have integrated (soldered onto the board, non-upgradable) CPUs. At this moment, NONE of them have AGP slots, and the standard is one singe PCI slot. They usually have a single DDR memory slot (Standard) and occasionally two.
I recommend checking out epiacenter.com, and mini-itx.com to get started in learning about them.
(Note: there is ONE new Mini-ITX board made by Kontron that was announced recently, that actually has a 4x AGP slot, and a PCI slot. It uses the Pentium-M processor. You can read about it on epiacenter.com.)
Hmm, my Pentium M Mini-ITX board has an AGP slot, but it's a miniature one.
1. I bought my board from globalamericaninc.com (U.S. distributor of Commell motherboards). So far they have treated me well. I will be making a customer service call soon, so hopefully that goes well.
2. I don't know of any Socket A Mini-ITX boards. There are Socket 370, 478, and 775 boards, though. There are also boards with embedded Transmeta Efficeon and AMD Geode GX1 processors.
3. You have to be careful with what you buy. Usually, the case is the limiting factor for component selection. Drives, RAM, and expansion cards must be carefully selected in the smaller cases like mine (Travla C137).
you can buy my epia m10000 itx its really small so you would need a different case or something, no agp socket, only one slot of ram, onboard video, its not bad,sorry but pm if your interested.
