G'ßöö;1030473188 said:ya gotta love forums when people just go off telling ya something, failing to really read what you're asking for. SOFTWARE wankers! maybe that input will help someone else tho. uG!
ya gotta love forums when the OP won't listen to valid advice
"Basically if you want louder output you should look into better speakers not your pre amplified output."
He's right. Software won't help you with more power, if anything you'll get a distorted mess. You need an amp or better speakers, buddy.
thnx..I thought maybe someone knows something but was sure "max'd is max'd". mp3's @ 320 are just fine its the shitty ones I was trying to get louder. will just look for better qualityThere's only so much power output you can get out of the amp in your speakers / sound card. If everything is maxed, it is just that. Maxed. It means you can't go any louder with your current setup.
