I want a TV card.
But I have never bought one or even paid much attention to them. I have a nVidia based system so what are my options? I am looking for something easy to use and fairly cheap. I just want to be able to plug in the cable and start watching TV. Does it work like that? :p
And I would also like to be able to record shows I want to keep. And what about the premium channels, how do I get them? Do I have to get anything from my cable company that I will have to pay more for? We already have two Digital boxes in the house. But if I can get a digital signal in here on my PC that would be great.
So what are my options?
A simple USB tuner is the easiest option. Plenty are available. A PCI card is sometimes more convinient. Those exist as well. Both are easy to use with software usually included on the CD. Your nVidia doesn't have an effect. There are fancier cards with hardware encoding or decoding, but you don't need this to simply watch tv or record normally.
Premium channels are difficult to get, I would advise to forget about them.
The HTPC forum is much more knowledgable than the general hardware one. Go there and read the FAQ.
